Question about Hotpoint VBXR1090D Top Load Washer
How do I remove the agitator for Hoover 700 LC?
Posted by mother_d_6_d on
  • Hotpoint Master
  • 17,130 Answers
The pulley and shaft assmebly comes off from the rear side after the top agitating rotor is remove off inside the drum from the top side.
remove the clips and pull out , the remove the pulley and push out the shaft and bearing assmemby.
Posted on Sep 25, 2010
How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
Feb 07, 2016 | Hoover Washing Machines
How do I remove agitator on a top loader Hoover 600mb washing machine?
remove the bolt in the centre of the agitator, usually a 10mm socket and extensions to do it and pull out
Sep 06, 2015 | Hoover Washing Machines
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
I have no owners manual and need to replace the belt on a Hoover powermax model #:U5242-930 can you help thanks Bab
I don't see this unit on the Hoover support site. However other Powermax vacuums come up in the search for manuals: http://www.hoover.com/CustomerService/manuals/Default.aspx .
Most of the units have very similar belt replacement procedures. First unplug the vacuum. Then press the handle release lever and place the handle in the low position. Next remove the hood by turning the two slots either side of the hood with a coin. Rotate the hood towards the front of the unit and remove it. Then remove the agitator brush roll and the old belt. Discard the old belt.
With the lettering to the outside, slide the new belt over the motor pulley. (The old belt should have been on the pulley. If the belt broke and isn't in place, look for it on the right as you look at the front of the vacuum above the agitator brush roller's position.) Slide the agitator brush roller through the belt and place the belt in the belt guide on the roller. Grasp the agitator and put it into position. Fit it into the rectangular slot on the left. Then pull it into position on the right side of the vacuum. Check if the agitator and the belt turn freely and that the belt isn't pinched between the agitator and the bottom of the unit. Replace the hood by aligning the tabs with the slots on the base. Then turn the coin slots to secure the hood.
I hope this helps.
Feb 01, 2011 | Hoover Powermax U5242-930 Vacuum
Hoover hspf167 agitator paddle How do I remove the old ones they appear screwed in at one end
Remove dispenser & filter from top of agitator. Down the bottom of the center of the agitator you will find a plastic cover. Pull this out with a bent piece of wire formed into a hook. Under the cover is a 10mm hexagonal head bolt. Using a long extension & 100mm socket you can undo it to remove agitator.
Jan 16, 2011 | Dryers
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Need to remove agitator on my hoover 500m washing machine
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Mar 12, 2008 | Hoover Washing Machines
Hotpoint VBXR1090D Top Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
