Hello- You may want to check the blower wheel for lint build up. It's not too difficult but you will need some TORX screwdriver bits, I think T10, T15,T20. Just get a whole set, it's probably cheaper. Make Sure the machine is unplugged before you do anything. Take off the lower panel, there are 2 hidden screws under the panel, once the screws are out just pull the panel off. On the left you will see a plastic cover with a wire coming out of the middle and i think 3 small screws (T10?). Take those out and pry the cover off carefully with a small screwdriver, there are retaining tabs that you have to bend back a little. Once it's off you can see the blower wheel (looks like about a 5" diameter plastic blower with louvers). Check to see if there is a bunch of lint built-up on it, I have seen this happen many times. If so clean it off and reverse process. The other thing that may be happening is that one of the 2 front support wheels is cracked, these are pretty hidden and a real pain to get off; best left to an Asko Tech. It could also be the rear bearing but I have never had to replace one of those. Anyway, good luck.
