ViewSonic N3735W 37 in. LCD TV Logo
Posted on Sep 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
View sonic flat LCD TV 32' turns power off.After charging cable is disconnected it worksfor a few seconds but turns off sfter that
Anonymous
Level 2:
New Friend:
  • Expert 112 Answers
  • Posted on Sep 24, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
112
Questions
0
Helped
24922
Points
355
You will need to open it cant fix it from out side better bring it to a technical center i can give you advices what to do when you got it open but i`m not edvising you to do this if you have no soldering skills
  • dvelja Sep 24, 2010
    I did open it.It has to do something with power suply i guess
  • Anonymous Sep 24, 2010
    Yes look at the capacitors first are there any whit caps blown or not flat look :http://www.pcstats.com/articleview.cfm?a...
1helpful
3answers
Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
1helpful
View Sonic TV wont power on
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
1helpful
View sonic 32 inch lcd tv has purpleish tint where black area used to be
ther is a problem in vertical area,just a capacitor only must be replace.
2answers
We connected the computer to polaroid lcd screen and it doesnt want to turn on can any one help me
l;kl
  1. Use a D-SUB cable to connect the PC’s D-SUB output jack to the LCD TV’s VGA input jack. Use an audio cable to connect the PC’s audio output jacks to LCD TV’s.
  2. Connect all AC power sources, before turning on the power switch of the LCD TV or other connected equipment.
  3. Press the button on the remote to turn on the LCD TV.
  4. Press the Input button on the remote to select COMPUTER.
ViewSonic TV sound but no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Akia 32 inch lcd turn on then shuts down, the only way to get it to power up is to disconnect power cable, let set for 20 to 40 seconds, reconnect power cable and then it will power up with no probelms....
In about 95% of the time when the TV is having a hard time turning ON or turns OFF by itself or needs to be unplug to make it work again; those are symptoms of dying or defective power supplies.
I repair these power supplies, if you need further info write to [email protected]
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
1helpful
2answers
No power, will not turn on
i have same problem.
tech support couldn't work it out, so i have to send it back....
hope to get any idea.
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
