Hi All, I have Panasonic SC - VK 540 music system. It has gone to the authorized service station several times for the above mentioned error. But unfortunately they have not bee able to fix the problem. The display does not show any error message before (like F61 etc.)switching of but makes a ***** sound similar to a relay toggle. Please Help ! Many thanks in advance Unmesh Deshpande
Posted by unmeshd2001 on
khan
Muhammad 2005 you can see there is cooling fain it not work properly com f61
Posted on Nov 17, 2012
  • 17,130 Answers
The fault seems to be a main board issue in which the relay is clicking but not activating.
SInce you are not aware of the work done earlier it must be seen if this was a reset issue. so power off and try to reset- refer you manual in thelast column for reset in case of errors...may be holding the menu/selecctor while switching on.
You can also see if there is any dry points in the main board,a loose connector or a connection . press and reset all connections
Posted on Sep 24, 2010
  • unmeshd2001 Oct 09, 2010
    Hi Caroldon,
    Thanks for the guidance. I did as you directed. Noticed that one transistor c3205 had loose (dry) solders so soldered the same. The problem vanished for a week before the unit going fully dead. I de-soldered the transistor and then checked the same on multimeter
My panasonic music system (SA VK-960) Is not working properly it shows (F61) error all the components are well attached with music system but there is still F61 error . Help us to resolve this error.
See page 40
Power Supply Error Code Table http://diagramasde.com/diagramas/otros2/panasonic_sa-vk960gc.pdf
Suggest checking power resistors in amp circuits for failed resistor. replace with identical rating in that the power resistors are used in the saftey circuits. Also check around these resistors for failed solder connection.
Hope this helps?
Jun 29, 2017 | Panasonic Audio Players & Recorders
Hi I have a Panasonic SA-PM200 mini hifi how do tune the radio stations
Make sure that you have the source set to FM or AM and the correct sound quality mode selected. Then press the Search track (fast forward or fast reverse) buttons on the remote. (These two buttons have the << or >> symbols and are on either side of the Stop button on the original remote.) If you press and hold the button, the radio will scan the frequencies in that direct until the next station that can be tuned in. The Skip buttons ('<< or >>') only goes to preset stations. As far as I can tell, these buttons are not on the main unit.
The remote is listed as part N2QAYB000639 . A replacement remote is available at several online locations including amazon.co.uk . See https://www.amazon.co.uk/Panasonic-N2QAYB000639-Remote-Control-SCHC15EBK/dp/B00H988QAM . The manual is available online here: http://panasonic.ae/en/manuals/SC-PM200.pdf . The SC-PM200 is the model for the entire system; SA-PM200 is the main unit. See section 7 for the radio tuning information.
I hope this helps.
Oct 28, 2016 | Panasonic Audio Players & Recorders
Won't read cd disk
We recommend you use the below link to locate an authorized service center in your area.
Welcome to Panasonic Online Repair
Apr 06, 2014 | Panasonic SC-AK27 Shelf System
I AM LOOKING FOR A REMOTE CODE FOR A PANASONIC
We would be happy to help with that. Here is a list of someof the codes that we have for Panasonic SC-HT940 System: 810, 799, 783, 643, 677, and 678.
Start by pressing and holding the AUX mode button until all mode buttons at the top of theremote light up, then release. Enter the number 2 then one of the codes for your Panasonic SC-HT940 System provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Panasonic System. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 24, 2010 | Panasonic SC-HT940 System
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
CANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
Jan 11, 2009 | Panasonic Home Theater System System
Vk 92 d power house
I have a VK-92 too.
I haven't such a problem yet!
Have u solved the problem?
What was the reason?!
Nov 19, 2007 | Panasonic Audio Players & Recorders
Help
Contact the panasonic factory service in your owners manual. I searched for that IC # and Its not listed in any of my sourse books. It may only be available through panasonic overseas? Good Luck
Apr 20, 2006 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
240 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
