Kicker 06ZX750.1 Car Audio Amplifier Logo
Question about Kicker 06ZX750.1 Car Audio Amplifier
My amp turns on the goes into protect mode. it does this repeatedly, green light red light over and over.
Posted by c_pena39 on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
You need to open it and check if there are no bad pieces
Posted on Sep 25, 2010
2 Related Answers
Anonymous
  • 245 Answers
SOURCE: power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Posted on Apr 27, 2009
Anonymous
  • 99 Answers
SOURCE: my kicker amp goes in and out of protection, like
Thankyou for the detailed fault description..it really helps!
sounds like there is one of these 3 things wrong:
1. leaky or partially blown mosfets on ouput power stage of amplifier are leaking DC onto speaker output causing amp to go into protect..this explains any banging or clicking herd.
2. There has been damage to the internal SMPS and is going into protect because of an internal rail over-voltage/under-voltage.
or 3. you have a shorted speaker lead or sub that is bringing the amplifiers load down to less than 2 ohms..buy or obtain a multimeter and have a poke around and check all your speaker leads on the ohm setting anything lower than 1.6 ohms and you have a short...also make sure that you have correctly loaded amplifier to..alot of begginer audio enthusiats overlook this important step and cook amplifiers!!
remeber impendance ratings, have a look on google, search "impendance formulas" and study up if your unsure!
hope this helps,ben
Posted on Jan 04, 2011
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
2helpful
2answers
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Hello. My Kicker kx200.4 is acting funny. The red display light on front/top of the amp is turning on for a second and then turning off, repeatedly. The light on the side (power) is also turning on, red...
the amp is a 200 Watt by 4 im guessing and its doing that because its going into protection mode unhook the subs if it stops then 1 you have a bad sub or 2 the subs are too much for the amp if an amp is rated 200w per chanel its 200 max about 75 rms or 75 normal constant power
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Still having amp problems
Hello lilmario,
After eliminating wiring problems and possible shorts, grounds and low impedance in the speakers, most likely the amp is failing internally. A partial failure of either the output MOSFET's or the thermistor. In either case, the repair requires removal and replacement of components on the circuit board. Depending of the age and original cost of the amp, such repairs are sometimes expensive.
I'd recommend having a professional audio shop test the amp and provide an estimate for repair.
Hope this helps.
1helpful
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
1helpful
Power light turns from green to red protect mode and then there is no sound coming from my speakers
2answers
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
