Wow ~ I spent some time trying to track this puppy down ~ but had no luck!
IF you have the original supply can you provide ALL of the numbers on it? Or perhaps a photo?
Also, if you can,
MEASURE the metal "jack sleeve" and sorry, but you've
GOT to provide that measurement in
MM ! Examples are 3.5mm and 2.5mm... both very common!
OR, I've saw ONE that
looked like a 'phone jack' and another with a white 'molex' or
oval connector??
In both cases above the will be VERY exotic and DIFFICULT to find!
>>> "I" would open the phone and SEE where the power connector is? I would get a common/low cost 7.5 volt DC power supply and SOLDER directly to the connector PINS or cut the wires to the connector and solder the power supply wires together... NOTE, the 'center pin' is usually + or POSITIVE! <<<
After several searches I found this on Amazon:
AC - DC ADAPTER 7.5VDC @
1 AMP 1.3MM DC POWER PLUG + CENTER
About $8
Amazon com AC DC ADAPTER 7 5VDC 1 AMP 1 3MM DC POWER PLUG CENTER Home...
RESEARCH AND TEXT TAKES TIME AND DEDICATION!
IF THIS HAS HELPED YOU ~ HOW ABOUT A "Thumbs UP"?
Anthony
