One possibility is that the design of the radio has been updated since the manual was published, and the newer version of the radio no longer includes the side power port. In this case, you may need to refer to a more recent version of the manual to get accurate information about the radio's features and specifications.
Another possibility is that your particular radio may be a different model or version than the one depicted in the manual, even though it appears to be the same on the surface. It's possible that this version of the radio does not include the side power port for some reason.
If you are still unsure why your radio does not have the side power port, you could try contacting the manufacturer's customer support team to see if they can provide more information. They may be able to clarify any discrepancies between the manual and your specific radio, or provide guidance on how to power the radio without the missing port.
To adjust the startup volume on a Bush DAB NE 3125 radio, you can follow these steps:
Turn on the Radio: Switch on the radio by pressing the power button or any other designated button.
Locate the Settings Menu: Look for a "Settings," "Menu," or similar button on the radio. It is usually represented by an icon or labeled accordingly. Press the button to access the settings menu.
Navigate to Volume Settings: Within the settings menu, navigate to the volume settings options. The exact location and naming of this option may vary, so refer to the user manual if needed.
Adjust Startup Volume: Once you've located the volume settings, you should find an option to adjust the startup volume. Use the volume control buttons or a designated adjustment knob to increase or decrease the startup volume level to your preference. Some radios may use a numerical scale or percentage system to represent the volume levels.
Save and Exit: After adjusting the startup volume, save the changes by following the instructions on the screen or pressing a designated button such as "OK" or "Save." Exit the settings menu to return to normal operation.
Note: If you're unable to locate the volume settings within the menu or the settings menu does not provide an option to adjust the startup volume, refer to the user manual specific to your Bush DAB NE 3125 radio. The manual should provide detailed instructions on how to adjust various settings, including the startup volume.
If you don't have the user manual, you can try visiting the Bush official website or contacting their customer support for assistance in obtaining a digital copy of the manual or for further guidance on adjusting the startup volume.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
I'd suggest starting with a radio harness adapter designed to provide wire-ends for the plug head in your tundra, I've found a few on eBay in this search:
