Question about Hoover AAA140 Front Load Washer
Drum not moving - Hoover AAA140 Front Load Washer
D. Floyd Kolb
  • Hoover Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 24, 2010
CAN'T GET THE SILVER PLATE IN SIDE THE DRUM IN CORRECTLY. THE DRUM NOW MOVES UP AND DOWN
Take off the outer covers all round the appliance and look at the back of where the screws you put in went, did they go into the correct places firmly?
I have got whirlpool condenser dryer model AWZ541/3 but the drum does not seem to move does the drum spose to move or not
yes the drum should move sounds like the belt has snapped or the start capacitor for the motor is faulty
Regards
Ian
Apr 17, 2011 • Dryers
Np 6412 copy dirty lines length of paper
Sounds as if the drum needs to replaced. How long has it been in the copier? They are supposed to be good for 30,000 copies or one year. It could also be dirty optics ( mirrors and glass ). Drum is easily installed by the customer. Just practice with the old drum - removing and re-installing before using the new drum. Too expensive to damage when installing. **** open the copier, Look under the control panel and you should see two levers. Move the right one to the right - this moves the developer away from the drum. Then move the left one down and this releases the drum for removal. Reverse procedure and power up the copier. It will automatically run and set the new drum settings into the copier.
1helpful
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
2helpful
Plastic things inside the drum have all come off,
If they have come off, it is because they are worn or broken.You need to fit 3 new ones
They are referred to as drum or clothes lifters, thier purpose being to move the clothes around.
Do not use the washer until you have got them fitted.
They usually slide and click into the slots in the drum.
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Maytag washer spin trouble drums moves from side to side
under the drum is a plastic support that can wear out. it must be replaced. if you do it yourself not too expensive
Thumping sound
Most likely the rear drum support has worn and dropped down.
Remove the drum and replace the rear ball and cup drum support.
Drum wont move
you should take off the bottom panel on the front of the dryer. there is usually 2 screws on the bottom. from there, you will be able to see if the belt is on and if you move the drum with your hand as you look inside, you will see if the belt is moving like it should
Hoover AAA140 Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Sheldon Dedek
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
