Question about Olympus Office Equipment & Supplies
Cash register ,continuous beep sound - Olympus Office Equipment & Supplies
5 Related Answers
Anonymous
  • 1142 Answers
SOURCE: casio cash register not working
error code 1 on your cash register is due to Mode switch position changed before finalization
you can fix this error by Returning the mode switch to its original setting (does not beep) and finalize the operation
Posted on Jan 23, 2008
Anonymous
SOURCE: sharp cash register displays error message E3.2
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You need to logon as there is no operator assigned to it. Press 1 then press CLK# or CASH# button.
-WN
Posted on Dec 16, 2009
Anonymous
SOURCE: there is a beep sound on my cash register when I
there is a beep sound on my cash register which is continuous. what it is?help me
Posted on Sep 28, 2010
Electroboy
Electroboy
  • 1868 Answers
SOURCE: Cash register doesn't register that I have scanned
Has this scanner been working on the register previously, or is this a new setup?
If anyone needs a Casio SE-S300 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Posted on Oct 16, 2010
Kasandre
  • 4 Answers
SOURCE: Our sharp ER-A310 cash register
E32 is usually an indication that the server or cashier has not been signed on. To resolve; 1) Press the clear button. Doing this will take you back to all zeros in the display 2) Enter the number 1 and then press the green or blue button which is labeled CASH, at this point you till have 01 in the display, indicating cashier 1 has been sign on.
Posted on Apr 05, 2011
Testimonial: "Fixed the problem thanx"
Uniwell cash register giving continuous beep not working any key
Probably lost the program. They will do that if the battery went flat from sitting unplugged. There are many uniwell programming manuals at Checkout tech: https://the-checkout-tech.com/manuals/cashregisters/Uniwell1.php
Dec 11, 2015 | Uniwell Retail Supplies
How can I clear a transaction and start over, when I keep getting an error message and beeping?
I would try to input an amount to see if it clears, if you still have manual that came with it there is a number that you can call for help
Mar 09, 2015 | Retail Supplies
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
!!! THIS WILL ERASE ALL PROGRAMMING AND DATA!!!
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
register.
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
Why cash drawer is not opening and beeping sound
Its possible that you are in training mode, just try to exit
Oct 20, 2014 | Sharp SHRXEA207 XE-A207 Cash Register,...
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
Cash register beeps cannot open drawer only the C button stops the beeps
I haven't seen this model but it sounds like you haven't logged on. Look up clerk sign on in the operation section of your manual.
Jun 24, 2013 | Casio Parts Cash Register PC Desktop
My sam4s ER650 cash register is just beeping at me INVALID ENTRY CLERK ERROR
Just press the clerk button its original position is on the top right...goodluck
Feb 04, 2013 | Samsung SAM4s ER-650 Cash Register
81 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
