what cellphone you use? its is n70>>>
try this!!!
First Method
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key
3) Turn the phone on
Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Backup your contacts list and personal files present in your MMC memory card to your system (if possible).
Second Method
on the screen of your mobile type *#7370#
you will be prompted for a Security Code.
This is 12345 by default if you haven't changed it.
Please ensure that you have backed up your data first onto a PC by using pc suite, or onto a memory card.
Soft Reset
The reset will restore all the phone's settings to factory default.
*#7370#
Hard Reset
Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
- Switch off the phone.
- Press CALL/Send button + * button + 3 button and then ON simultaneously until the phone is completely started.
note: The default password is 12345. You need to press and hold the key until the number appear.
Soft Format for Nokia Symbian Series 60 Phones:
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature and your set will be like a fresh phone.
Hard-Format for Nokia Symbian Series 60 Phones:
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
Method 1: Use the following code
7780#
note: before u do this make sure u dont have mmc cuz if you have the virus will b tranzfer at ur mmc or memmory card!!!
try the hard format
this is
-green dial key
-the star key(*)
-the number 3 key
if the memmory have a virus just format at pc...
100% working!!! i try that many times
