SanDisk Sansa e200 MP3 Player Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I added a 8GB micro SD card to my e200 MP3 player but the player won't recognize the card. What do I do?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • SanDisk Master 102,366 Answers
  • Posted on Sep 24, 2010
SanDisk Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443620
Points
622693
You need to use microSD cards, 2GB and smaller. Your 8GB card is actually a microSDHC card (the HC stands for High Capacity). While a microSDHC card will fit into the slot, they are incompatible with the Sansa e200 series.
2helpful
2answers
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
2helpful
Sansa e200 wont recognize 8GB microSD
The Sansa e200 series machines work with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use microSD cards, which are 2GB and smaller.
Later model Sansa such as the Fuze will work with microSDHC cards, but not the e200. Sorry if this wasn't the answer you wanted to see, but that's the way it is.
1helpful
I am considering purchasing a Sandisc Micro SDHC 8Gb card for my Sandisc E260 MP3 Player. Will this be OK?
Highest capacity memory card for the e200 series depends on the firmware version.
Consulting the Sandisk page gives next information:
Sansa e200 - verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
1helpful
Sansa e260 doesn't recognize my 8GB sandisk expansion card
Sandisk sansa e200 series players only allow up to 2GB expansion, BUT with rockbox firmware up to 32GB is available. Only download rockbox firmware if your familiar with transfering and installing files.
Rockbox firmware can be found at http://www.rockbox.org/
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Sd card problems
try downgrading the sd card make it a 2 gb card
Sansa E250R doesn't recognize a 8GB card nor does my computer
Is you E280 V1 or V2? The V1 will only recognize up to 2GB. You can find this by going to settings, info. If the firmware number starts with 1 it's a V1. V2's start with 3.
If you have a V2 place the card in a card reader to format. Format card to FAT32. If not recognized by a card reader the card may be defective.
If the player is a V1 the micro SDHC can still be used by loading RockBox firmware. But note when running RockBox the sync port will be disabled. To use port the player can still be started in the Sansa firmware but a SDHC card will not be accessible.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Not recognizing the memory card
if the micro sd is HC the sansa will not read it because it does not have the right firmware and connection to read an 8 GIG if you want that get a sansa view
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
2helpful
6answers
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
