Pentax Program Plus 35mm SLR Camera Logo
Question about Pentax Program Plus 35mm SLR Camera
I have a Pentax ME Super and whenever I press the shutter button down, regardless of whether it's in auto, manual or 125x mode the shutter will stay open for the amount of time my finger holds down the shutter button. It acts like 'B' mode for every other mode, and I have no idea how to fix it.
Posted by alexander_og on
M_Butkus
    Habit-Forming:
  • 120 Answers
One old camera. You have an electronic shutter and mechanical (backup) so you may have a dead electronic shutter. I would check the battery and contacts. If they are good... the shutter is bad. You have a standard K-mount body, any lenes will fit any Pentax camera, film or digital. The lenses will go on more modern Pentax bodies but will not auto-focus if on an AF body. These bodies are some 25+ years old, many places are selling them for $30 or so.. there are just thousands out there. If you want to stick with film, go for a newer AF body and you can still manually focus.
Posted on Feb 20, 2018
1 Related Answer
Anonymous
  • 58 Answers
SOURCE: Pentax ME Super Seems to alway be in bulb mode.
There is an arm in the seiko shutter assembly used in this camera which selects auto, 1/125, and 'B' modes. It's a purely mechanical thing.
Something may (HAS!) have got into the shutter works and jammed it in this mode. You will have to open it up to see what this is.
It is quite likely that the offending something, is one of the synthetic rubber bumpers fitted to make the mirror a little quieter, or perhaps the spring that locks the winder into it's 'home' position has broken. The bumpers are all breaking now, and need to be removed. The springs break in some due to fatigue. (Not all though. The metal seems to be very variable in quality for this part.)
To see how to open the camera up for repair and how to do this properly there is a camera repair site which deal with this and other cameras in detail. alternatively you can contact the author who can offer a very competitive camera repair service for these models.
Posted on Jan 21, 2009
2helpful
Pentax me super shutter won't open. won't wind, wont take a picture :(
Have you not used it in a while?
This could be one of two issues:
One, it could be the battteries. The ME super is not a fully mechanical camera like the mx, if the batteries are depleted then the shutter sticks open as it does not know how long to stay open. Turning the selection wheel to 125X usually unsticks it.
Two, the lubricant that pentax used in the 70's and 80's has a very bad tendecy to polymerise and turn sticky and solid. This turns the camera inoperable. Pentax repair service routinely provide cleaning for affected cameras.
Hope this helps, its a great camera
I have a pentax me super that was recently given to me, and i have replaced the batteries however there is no indication at all from leds. i am not sure if it is broken or if there is something i am...
First, check that you've inserted the batteries the correct way up. the positive terminals face down as you hold the camera inverted. Also check that the camera's battery terminals are bright and clean.
With the batteries inserted and the battery cover in place, set the camera mode selector to Auto or M (manual) and lightly press the shutter whilst looking into the viewfinder. If the batteries are good one of the LED's from 4s to 2000 will light steadily. If they don't then you have a faulty camera and ME Supers are not easy to fix and the electronic parts which usually let them down are very hard to obtain. It's perhaps forgiveable when you think that these cameras are nearly 30 years old now... Not really a problem though as there were so many sold that it's usually fairly easy to obtain another for free (good old FreeCycle and Freegle) or very cheap, but a bit more difficult to find one which still works correctly in all respects.
The ME Super is very limited without batteries as the light meter won't work. By setting the mode selector dial to 125X you get the single mechanical shutter speed of 1/125 of a second.
If you want a free download of the user manual, it's in two parts as a pdf file on the Norman Butkus website
Shutter stays open
According to what you say, it seems that you selected B (Bulb) as shutter speed (and MANUAL mode).
First, check whether you are on MANUAL mode ("M"); then, check your shutter speed. If it's really in "bulb" mode, all you have to do is dialing the speed button down to figures that match your subject's light conditions and your other preferences involved in the exposure (ISO, lens apperture).
1helpful
2answers
How do you change the shutter speeds on an pentax k100 super, when it is on the AUTO PICT setting?
You can't.
In Auto Pict mode the camera selects the best of the pre-set Scene modes for the photograph which you're about to take. It's basically a variation of fully automatic mode, so the camera selects everything for you.
Auto Pict and Auto are designed to let anyone pick up your camera and take a fully automated snapshot without needing to worry about what settings to use.
To alter the shutter speeds you need to select an appropriate mode such as shutter priority or manual.
Shutter does not work..could it be the battery
Yes, it could. Try to shoot with 125x-mode to check if the shutter works on manual. If there are no lights coming up in the metering pillar it is very probable that hte batteries are gone.
1helpful
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
1helpful
2answers
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
2answers
Hello igby Slocumb,   As I recall, this was Pentax's way of mating electronics with mechanical cameras and the success rate was quite good. The only problem with the Pentax Super Program was the rather complex electronic circuit board. Your canera could have bad batteries, or batteries with too low amperage therefore no electronic shutter, have a short in the wiring, etc. You would need to do a shutter circuit check using a benchtop AC/DC power supply to exclude the batteries. Wow - really expensive and time-consuming = complete stripdown and repair. The camera is over approximately 30 years old making it a classic. It is no longer in production meaning parts need to be cannabalized from another old non-working Pentax Super Program. The cost of repair would exceed the value of the camera. Look for another good used model or move on to a Pentax DSLR (digital SLR) camera as your tool. Sorry I couldn't give you a better answer on how to fix your problem.
2answers
Hi could you answer a question for me about the pentax mv
The Pentax MV has a similar body and uses the same lenses as the Pentax ME Super, but it is a fully "Auto Exposure" camera. It does not have manual override or shutter-priority modes. It is a good camera to take pictures, but not if you want to have full manual / creative control over the camera.
Take care & Happy Imaging!
Glen
Pentax ME SuperProgram shutter button doesn't release shutter
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: http://mcfaddenphoto.com/camera_manuals/pdf/ME_Super.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Top Pentax Photography Experts
Steve
Are you a Pentax Photography Expert? Answer questions, earn points and help others
