Look near the disk tray for a little tiny pin whole and take a paper clip and bend it straight now poke it into that whole until it open this is the manual way of ejecting disks if all else fails
Http://pdf.textfiles.com/manuals/ELECTRONICS/AV/CC-222MK2_manual.pdf Here's the link for the Owner's Manual. Hope that helps.
SOURCE: cd will not eject. Keeps giving message "Now OPC"
To remove a stuck CD from Tascam CC222
MKII This solved the "Now OPC" problem 1. Unplug unit 2. Remove the top cover, (3 screws on each
side and 3 on the back, lift cover). 3. Plug in unit. 4. Power on the unit to observe the drive
spindle spinning clockwise, (1" disc on top of drive). 5. Turn off unit, do not unplug at this
time. 6. Use a small screwdriver to prevent the
drive spindle from spinning. 7. Power on the unit preventing the spin. 8. In approximately 10 seconds the display
will read "Disc Error" and the CD tray will open. 9. Remove the screwdriver and the disc. 10. Turn off the unit and unplug. 11. Replace the cover. 12. Use a better quality disc.
MKII
1. Unplug unit
3. Plug in unit.
time.
http://pdf.textfiles.com/manuals/ELECTRO... Here's the link to get an Owner's manual.
Okay, so with respect to Stubbornguy's solution...it might work but it might damage the device. According to the manual it specifically states "Caution: DO NOT REMOVE THE PROTECTIVE HOUSING USING A SCREWDRIVER" Probably because of the digital devices inside that would get ruined with the magnetism that is on the screwdriver. It also states to keep this device away from magnetic fields.
However, as to the problem it may have to do with the disc as Stubbornguy states. The manual states NOT to use "Stabilizer CD's" or "Printable recordable CD's". The latter is what I was about to use. Evidently the adhesive on the printable label causes the CD to stick in the unit and cause the unit to malfunction. According to the manual it will take a technician (more likely tech's tools) to open the unit and remove the CD, without further damaging the device. I hope this helps.
