Question about Canon LV-X4 Multimedia Projector
My Canon LV-X4 is attached to a USB extender. After replacing the extender my image has dimmed significantly. The "replace bulb" light is not on. Is my problem with the extender?
Posted by sahennis on
Anonymous
    Problem Solver:
  • 14 Answers
There might be, can you tell the make of your device, Icron is the biggest and also the best maker of usb extender.
Posted on Sep 24, 2010
Canon lv- x5
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Pew71 display suddenly dim
did you also replace the inverter??long ish piece of board two long wires attached.this is used to light the bulb on the screen,also if you turn the pc to a light when switched on can you see any image will be faint???if you can it will be the inverter..also the screen you put in are you sure the light works. hope this helps
Dec 12, 2013 | Acer Computers & Internet
Canon LV-S1 projector keeps shutting down after a minute or less
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Smoking Canon Projector and Dim picture
Is there suppose to be a fan that blows while it is running? Most projectors have a blower otherwise the bulb overheats. If the fan runs do you have something like a book or something that is blocking it?
Jun 01, 2017 | Canon LV-S4 Multimedia Projector
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lv-s1 canon projector
Hi there
Open up the unit and replace the fuse on the Powersupply ( where the AC inlet sits )
If this doesn't do the trick you will have to replace the Powersupply itself.
But most of the time it is only the fuse that has gone.
Apr 14, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lamp problem
Could be an overheat problem, check any fans and filters are not clogged with dust, lack of ventilation and cooling will trigger a safety shutdown
Feb 06, 2007 | Canon LV-LP11 Projector Lamp for LV-7345,...
Canon LV-X4 Multimedia Projector Logo
old marine
old marine
efs_perpends
efs_perpends
