Sony CPD E400 19" CRT Monitor Logo
CARL BASNER Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CONNECTED MY MONITOR TO MY NEW MAC INTEL OS X 10.6 SNOW LEOPARD, AND THE MONITOR JUST SITS THERE, YELLOW LIGHT IS ON, SAYS IT IS IN POWER SAVE MODE, MONITOR PROGRAM IN COMPUTER CANNOT DETECT DISPLAY, DIS CONNECTED IT FROM MAC OSX 10.5, WHERE IT WORKED JUST FINE. SONY CPD-E400, IN POWER SAVE MODE, TRIED TO TAP ANY KEY ON KEY BOARD
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Sep 23, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955975
Points
33084
Did you tried CPD-E400 with any other computer? If not, connect it with any other Windows PC and check.
I do have schematics of this monitor that is why asking to narrow down the problem.
Thanks.
tip
How to set Mac OS X 10.6 (Snow Leopard) to run in 64-bit mode
There are two ways to set Mac OS X Snow Leopard to run in 64-bit mode.
The first way is quite simple: you just have to hold down "6" and "4" keys while the system is booting up.
The second way is simple as well. You only have to search for a file named "com.apple.Boot.plist" in /Library/Preferences/SystemConfiguration. Open it with Text Editor and edit line 9: where it reads "<string></string>", change to "<string>arch=x86_64</string>". Without quotes, of course.
Using the second way, Mac OS X Snow Leopard will boot in 64-bit mode whenever you turn on your computer.
PS: 64-bit mode is available just in some machines like MacBook Pro and Mac Pro. To check if your Mac supports 64-bit mode, write the following command in Terminal, again without quotes: "ioreg -l -p IODeviceTree | grep firmware-abi". You will get the answer "firmware-abi" = <"EFI64"> if your system can run in 64-bit mode or "firmware-abi" = <"EFI32"> if not.
on Apr 10, 2010 • Computers & Internet
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
2helpful
Can I put Apple's Mac OS Snow Leapord on my apple eMac?
Unfortunately Snow Leopard is only compatible with intel macs which the emac is not.
5helpful
2answers
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
6helpful
2answers
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
When I try to use my safari browser with my mac os10.6.1 I receive the following mwssagethat safar i4.03 will not work with my mac os.
If you updated from Leopard to Snow Leopard you should note that safari for Snow Leopard is different from that for Leopard. Do a clean instal of Snow Leopard and that should sort the problem out. Hope this helps
Mac os x Snow Leopard
Apple's next major Mac OS X released, will focus solely on under-the-bonnet changes, the Mac maker has revealed. PowerPC-based machines might be left in the cold?
Apple is promising a version of Mac OS X that "dramatically" reduces the amount of storage space the operating system requires. Undoubtedly, some of that will come from the re-engineered core technologies, but it's hard to conclude that Snow Leopard's release will come not as a "universal" binary capable of running on both Intel and PowerPC processors, but as a single-platform product.
Universality has been handy in ensuring users can run the same installed code on both Intel- and PowerPC-based Macs without resorting to emulation. But just as Leopard lacks the ability to run Mac OS 9 apps - a feature present in previous Mac OS X releases - there will come a time when Apple drops Rosetta, its PowerPC emulation mechanism.
Early rumours concerning Snow Leopard suggested PowerPC support was to be dropped, though that was subsequently denied by Apple.
How can these two claims be reconciled? Only by Apple shipping native-only versions of Snow Leopard. Owners of Intel-based Macs will finally be free of all that redundant PowerPC code in the system software, freeing up space for, as Apple puts it, "their music and photos".
With any luck, Apple will finally allow users to readily remove unwanted languages from their system software, a process that can free up a fair bit of hard drive space too.
Apple won't be ditching support for universal binaries, or PowerPC Macs, because there, for now, too many of them out there. But if Snow Leopard's Grand Central technology does as promised and improves the OS' ability to work with multi-core CPUs, Intel-based Macs are going to shoot even further ahead of old G5 and G4 models.
Apple is also promising that Snow Leopard will offer more pervasive support for 64-bit computing, leading to the ability to support up to 16TB of memory, though the motherboard hardware to do this isn't there yet. In any case, limits to CPU memory controllers mean they don't physically support the full range of 64-bit memory addresses, only a subset.
Snow Leopard will also feature QuickTime X, a "streamlined" revamp of Apple's multimedia foundation, and OpenCL (Open Compute Library), a non-proprietary programming system for running complex code on a machine's graphic chip(s).
Oh, and it'll get Microsoft Exchange support too, in a bid to make Macs more business-friendly.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
