Question about Xerox Phaser 7400/DXF Laser Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
Posted by bgeary on
Anonymous
    New Friend:
I am getting a report fault 917 error on the phaser 7400
Posted on Jan 07, 2011
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 displaying error code u60. Even after rebooting.
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Dec 17, 2009 | Xerox Phaser 7400/N Printer
Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Nov 02, 2009 | Xerox Phaser 7400/DXF Laser Printer
Xerox 7400 error 917
From Google: Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
May 25, 2009 | Xerox Phaser 7400/DT Laser Printer
917 error code
That is a transfer belt error, The edge of the belt is not being sensed.
Take the transfer assembly out and reseat it. if that doesn't fix it, return the belt assembly for a warranty exchange. Sometimes just taking the transfer assembly out and putting it back in retracks it properly.
Feb 14, 2009 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400 not printing red
I would suspect you do not have drive to the red imaging unit area. A gear may have fractured, a motor not runing, which would normally give you a fault code, or a clutch is slipping not driving the red components.
Jul 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Eric Engel
efs_perpends
efs_perpends
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
