log into the router and change the access code (by that I assume you mean the wifi security key). Simple process , in the manual which can be downloaded from dlink.
If your WiFi Router are not connecting to the modem then you can contact us Dlink Tech Support . Our Toll Free Number 1-855-239-6292 Dlink Tech Support
There are ways to configure router: 1. Is by using Installer using a CD came with it or 2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note: Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
You'll need to log into your router to set up a wireless access code. If you still ahve the users manual, use that as a guide, and you'll need it for the IP address that will allow you to connect to the router. It's a string of numbers such as 192.168.0.1 that you'll put into your address bar in your web browser. You'll then be promted for the routers default user name and password, which should also be in your users manual.
