Question about Samsung SGH-A877 Impression Cell Phone
How can i change my password on my sim card to use my phone?
Posted by scubaaasteve on
William Norris
    Scholar:
  • 107 Answers
If you forgot your sim password (PIN) enter a code 3 times to get the phone to ask for puk code then call your carrier for the puk code and that will allow you to set a new pin
Posted on Sep 23, 2010
How do you unblock your phoe when your PUK is blocked
your SIM card is VOID meaning it does not work any longer. That means you must contact your service provider, and they will have to send you a new SIM card. This happened to me once before, and it was a pain. :-( Anyways I did'nt get charged for the new SIM card though.
Hope this what you were looking for, and next time just remember not to enter the PUK code too many times without knowing the code, contact your provider first hand.
Hope this helps
Mar 13, 2010 | LG Xenon GR500 Cell Phone
I FORGOT MY PASSWORD PLS HELP ME .MY MOBILE IS NOKIA 5300
Relax...
The first step is to find out if the password is on your sim card.
If you already know that it is on your sim card skip this step. Turn off your phone and open it up. You should see your battery. On most phones your sim card is located under the battery. When you find your sim card remember exactly how it goes into it's slot and take it out.
Put the battery back into the phone and turn it back on. It will tell you that your sim card is missing and on most phones ask you if you want to start without a sim card. Press yes and see if it asks you for your password. If it does not, then the password is on your sim card. Put the sim card back into your phone and call your service provider. Tell them that you forget the password to turn on your phone. They should be able to tell you what you password is after they ask you a few questions.
If the password was not on your sim card, then call your cell phone provider and ask them how to reset your password.
Service provider: Verizon, Vodafone etc are service providers.
Cell phone provider: Samsung is a cell phone provider.
Please inform if your problem is solved or not. If not, then we will see what we can do.
Aug 26, 2009 | Samsung SGH-e315
I have a LG dare and forgot my password to unlock my phone
The first step is to find out if the password is on your sim card. If you already know that it is on your sim card skip this step. Turn off your phone and open it up. You should see your battery. On most phones your sim card is located under the battery. When you find your sim card remember exactly how it goes into it's slot and take it out. Put the battery back into the phone and turn it back on. It will tell you that your sim card is missing and on most phones ask you if you want to start without a sim card. Press yes and see if it asks you for your password. If it does not, then the password is on yor sim card. Put the sim card back into your phone and call your service provider. Tell them that you forget the password to turn on your phone. They should be able to tell you what yor password is after they ask you a few questions. If the password was not on your sim card, then call your cell phone provider and ask them how to reset your password. Service provider: Verizon is a service provider. cell phone provider: LG is a cell phone provider.
Aug 17, 2009 | Samsung SGH-e315
I bought a cell phone from a friend
sounds like the phone was set up to ask for a sim password from the old user. Now that you put your card in it wants the password but the phone does not know the card has been switched. Ask your buddy the code to unlock the bios and disable the password. If al lelse fails put his old sim card back in and then disable the password for the sim card. This feature is a security so people cannot access your contact stored on your sim card.
Joe
May 27, 2009 | Motorola Mobility V180 Cellular Phone
How do i unlock my PUK lock
It seems you encode a wrong sim card password?
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call your phone service company, they can retrieve the puk code from a database
for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone should not ask for the PUK anymore.
thanks,
Mar 20, 2009 | HTC Google G1/Dream Cell Phone Black...
Sim card rejected on nokia 2630
is it the same sim u used in setting the password? insert the original sim and change security settings to none
Feb 06, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Sim card rejected
hi
you can call the company from another phone and fix the problem by giving them the PUK number.
i hope this will work
Jan 06, 2009 | Nokia 1600 Cellular Phone
Need master password for my samsung sgh-c425
I found this off another site. I have tested this withy my D807 and it works.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin)
3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone.
Jan 03, 2009 | Samsung SGH-C425 Cellular Phone
Unlocking my Samsung-d807
okkk now turn off your phone and remove sim card then start your phone without sim card then type this code *2767*2878#
Dec 11, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-A877 Impression Cell Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
