2007 Jeep Grand Cherokee Overland Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the oil capacity for a front & rear axle for a Jeep Grand Cherokee 3.0
Anonymous
Level 3:
  • Master 2,926 Answers
  • Posted on Sep 23, 2010
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1004855
Points
9623
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Transfer Case (3.7L Engine)
Mopar® ATF+4 Automatic Transmission Fluid
Transfer Case (3.0/4.7/5.7L Engines)
Mopar® NV 247/245 Transfer Case Lubricant
Transfer Case (6.1L Engine)
Mopar® NV146 Transfer Case Fluid. Usage of other fluid/lubricants is NOT recommended.
Axle Differential (Front-Rear)
Mopar® Synthetic Gear & Axle Lubricant SAE 75W-140 (API-GL5) or equivalent with friction modifier additive.
Are any of the parts on a 1997 Jeep Grand Cherokee interchangeable with a 1999 Jeep Grand Cherokee? rear axle,wheels, power-steering, hood hyrdraulics?
A few parts should be interchangeable. Most of them will not be however since the Grand Cherokee underwent a complete re-design for 1999. Some engines and transmissions will switch out. The rear axle in the 97 was commonly a Dana/Spicer 35. This was replaced with a larger rear differential in 1999 for increased towing capacity. The wheels should interchange ok, power steering system was pretty much the same and as long as the hydraulics (supports) on the hood are the same length they should work
Front wheels want to banding up when your turn the wheel on a 1993 jeep grand chrekee
You may have differential trouble,check the oil levels in your diff's front and rear axles.Or you have a C.V joint gone.
1helpful
How do I change the front and rear shocks on my 99 cherokee?
FRONT:
Removal & Installation
  1. Remove the nut, retainer and grommet from the shock stud in the engine compartment.
  2. Raise and support the front axle.
  3. Remove the lower mounting nuts from the axle bracket.
  4. Remove the shock absorber.
To install:
  1. Position the lower retainer and grommet on the shock stud. Insert the shock absorber through the shock tower hole.
  2. Install the lower shock studs into the axle bracket.
  3. Install the mounting nuts and tighten to 250 in. lbs. (28 Nm).
  4. Remove support and lower the vehicle.
  5. Install the upper grommet, retainer and nut on the stud in the engine compartment.
Rear:
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove or disconnect the following:
    • Upper locknut and washer from the frame bracket stud, on the Grand Cherokee
    • Lower bolt, nut and washers from the axle shaft tube bracket
    • Shock absorber
To install:
  1. Place the shock absorber upper end in position and tighten the fasteners to the following specifications:
    • Cherokee: 17 ft. lbs. (23 Nm)
    • 1999–01 Grand Cherokee:68 ft. lbs. (92 Nm)
    • 2002–04 Grand Cherokee: 80 ft. lbs. (108 Nm).
    • 2005 Grand Cherokee: 70 ft. lbs. (95 Nm).
  2. Place the shock absorber lower end in position and tighten the fasteners to the following specifications:
    • Cherokee: 46 ft. lbs. (62 Nm)
    • 2002–05 Grand Cherokee: 115 Nm (85 Nm).
    please do not hesitate to ask any further questions about your vehicle i would be glad to help you.
  3. do not forget to rate and comment about your experience with fixya...
Scrubbing noise from rear
check the sheet metal backing plate just behind the brake rotors, it may be bent and touching when wheel is turned, this is the common problem for this noise.
1helpful
15k front & rear axle oil change 15k pressurized fuel injection flush & throttle body service
so whats the question? It sounds like you have a auto repair chain store after your money, skip it. follow the owners manual service schedule.
1helpful
2answers
RELACING WHEEL BEARINGS IN A 95 JEEP GRAND
Front wheel bearings can be done at home rear wheel bearings will require a hydraulic press and an axle puller. Either job can be difficult depending on amount of rust and availability of tools. The front wheel bearings are an assembly and once the jeep is up on jack stands, with the tires, brake calipers, and rotors removed, it is only a matter of removing the axle nut and 3 bolts (which can be difficult depending on rust) holding in the old bearing assembly
1helpful
4answers
Rear end (axle)
call jeep and give them last 9 digits of your vin and ask for three things -Differential Type,Gear ratio, and Track lock- They will give you
1) Dana 35 or 44
2) Gear Ratio 3.31 or 3.73
3) Track Lock - yes/no
1helpful
Jeep GC axle oil change
undo the lower plug on your diff housing,drain tighten plug up, undo top plug fill til overflow,same as front,oil refer to owners manual or call local service centre
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
