Logitech R-20 Computer Speakers Logo
Posted on Sep 23, 2010
Logitech R-20 The power on my speakers won't turn on, the power stays on when i hold down the power button on the speaker itself, but when i let it go the light turns off on the speaker. In order to hear sounds on my computer i have to hold down the power button, any solutions please? PS everything is connected nothing is wrong as far as what i can see
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1243
Points
I have this problem toooo
Anonymous
Level 1:
New Friend:
  • Posted on Jun 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1243
Points
Open up the speaker and completely remove the spring and power button 'cap'. should reveal a blue square button. Then place the cover back on. to turn on and off just use something like pliers to push the on/off button in and out. Worked for me
How do i reset my i-pad?
Hold down the power button and the home button for 10 seconds
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Automatically turns on when i plug power cord in, no sound to speakers,won't turn off when i press the power button
Depending ont he model you can reset the receiver by holding video or vcr on down for 10 - 20 seconds. it depends on the model. it should display reset on the receiver then restart. otherwise it could be simply a broken power button that needs to be replaced.
1helpful
My logitech r20 speakers problem is when i switch on ,there is no power come out,but then if i push a bit n hold ,there is power come out,.if i release back my hand switch it to normally the button...
The power button on your speakers is broken- possibly from friction due to heavy usage. Unfortunately, there is no way to really fix this that is worth your time- if you still have it under warranty, take it to where you bought it, or give Logitech a call to get them replaced. If you don't, it may be time to search for a new set. While it's more expensive, I would recommend the Logitech Z-313 or Z323 if you want a decent replacement. They will sound better than the R20s, too.
6helpful
3answers
Control station won't turn on.
That sounds like a hardware faulty i can only advise you to contact logitech.
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Logitech z2300.
Make sure you you have turned on both of the power buttons the one on the remote should be pushed down and there is also one on the back of the subwoofer just above the power cord connection. Hope that helps if not just let me know
33helpful
6answers
Panel lock on dra 397
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
