Question about Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Posted by pnlvalentine on
Anonymous
    New Friend:
  • 10 Answers
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Posted on Jan 03, 2011
Mother gave me her filterqueen defender.. no manual. 360. There is a flashing red light even though its a new filter. Why?
The light is a reminder to change the filter, it does not sense if the filter has been changed or not.
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 28, 2010 | Filter Queen Defender Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
Dec 09, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
Nov 19, 2010 | Filter Queen Defender Air Purifier
Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
http://www.filterqueen.com/pdf/defender.pdf
May 27, 2010 | Filter Queen Defender Air Purifier
Defender air purifier
If you have replaced your main filter you need to reset the red light. If you have not replaced the main filter you will need to contact your local filterqueen distributor. If you go to www.filterqueen.com they will direct you to your closest distributor and they can walk you through over the phone on how to reset your red light.
Feb 15, 2008 | Filter Queen Defender Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Filter Queen 3000A Defender Air Cleaner Manual
http://www.filterqueen.com/pdf/defender.pdf hope this helps :)
Mar 12, 2007 | Filter Queen Defender Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Programing
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf Hope this helps :)
Oct 30, 2006 | Filter Queen Defender Air Purifier
Filter Queen Defender Air Purifier Logo
368 people viewed this question
Top Filter Queen Air Purifiers Experts
ray gallant
Tom Chichester
Are you a Filter Queen Air Purifier Expert? Answer questions, earn points and help others
