SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
SOURCE: looking for manual for a
you can download manual from this link below
http://www.devicemanuals.com/guide/Display%20and%20Video/NEC/NEC-MultiSync-LCD1960NXi-BK-User%27s-Manual-==TXpFMk1qVTQ=.html
