It sounds like the problem could be caused by the fact that the heating element, or the hot water sensor, has failed so that the washer will not proceed with the wash program until the water is up to the correct temperature. You should be able to easily tell if the element is getting hot. You could try manually putting in hot water before the washer fills up with cold to see if the wash then proceeds which will mean that the heating element needs replacement.
