Just fixed one at work today for a bloke I work with it had the flashing AUTO light & turns off after a couple of seconds. Keep in mind I've never fixed a vacuum cleaner before but i am an electronics technician so it wasn't too hard. I'll list how I did it best I can from memory.
What caused his to do this was where the hose connects to the unit there is 3 wires you can see this from the three prongs where it connects. Take off the hatch on the hose with a size 8 Torx driver. once Off you will see three loops of metal and the part that separates will have three contacts with wires leading to the prongs. What happened to his was the middle loop came off and the wire under it had broken free and I suspect shorted to another contact.
I soldered the wire back to the ring and shaped it back together holding it with solder.
Take the cleaner apart I think you need a 20 or 25 Torx driver to do this.
Its tricky and can't remember exactly how to do it without the unit in front of me.
What your looking for is a circuit board on the side of the unit. theres two of them you want the bottom one the top one is for power regulation. theres also the one at the top with the LEDs etc don't worry about that.
On this board inspect the FUSE its a 250V 3.1A and its soldered in, I replaced it with a 3A since it was all I had.
Test it and remember to attach the nozzle back before powering it on. From what I can tell those three metal loops are antennas for the controls on the handle.
The one I fixed was a Z88701p I think Australian model.
Thanks evlspcmk your fix worked for our Ultraone! On the end of the hose which plugs into the machine the three prongs are part of a small plastic panel that can be lifted off once you remove the torx screws. On the underside of this panel you will find the wires and in our case one of the wires soldered to the prong has come apart. I soldered it back and now the machine works perfectly! Was about to throw it out so very happy.
we have an electrolux ultraone and today when we - electrolux-ultraone-today-when-2rhfx5f4twqfuwdkmu001nlo-5-3.jpg2rhfx5f4twqfuwdkmu001nlo-5-3.jpg" alt="electrolux-ultraone-today-when-2rhfx5f4twwe have an electrolux ultraone and today when we - electrolux-ultraone-today-when-2rhfx5f4twqfuwdkmu001nlo-5-4.jpgrc="/uploads/images/electrolux-ultraone-today-when-2rhfx5f4twqfuwdkmu001nlo-5-4.we have an electrolux ultraone and today when we - electrolux-ultraone-today-when-2rhfx5f4twqfuwdkmu001nlo-5-5.jpglo-5-4.jpg" class="h_mi" />
SOURCE: my electrolux ultraone keeps cutting
This is not an Electrolux Lux 7000. Totally different companies.
However, check the hose for clogs. Drop a coin down one end and lift so it should drop out the other. If it doesn't, there's a clog that needs cleared. This can often be done by pushing it out with a broom handle.
Note that this is not an Electrolux Lux 7000, but an Electrolux Ultra-1 or Ultra One. These are two completely different manufacturers, machines, and have different service needs.
We have the same problem, is there any solutions?
just fixed one at work today for a bloke I work with it had the flashing AUTO light & turns off after a couple of seconds. Keep in mind I've never fixed a vacuum cleaner before but i am an electronics technician so it wasn't too hard. I'll list how I did it best I can from memory.
Thank you very much. It worked. I soldered the rings, but I am not sure they will survive for a long time.
