SOURCE: Sony FD Trinitron WEGA KV 32FS120
This model does not have a G board. I will post when I have this solved.
SOURCE: Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
SOURCE: sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
SOURCE: My Sony Wega standby light is blinking 9 times,
Need to check D647 which is a diode sony part number 6-500-567-01 even if it checks good probley need to replace. Also need to check Q 691 part number 2SA933AS-QT which is a transistor may check good but should replace, it crosses to a ecg part number 290A . Also should check D 645 which is the same part as D647 it looks like you cand use a ECG diode part number 552 for theses diodes. If u dont know anything about tv repair u might want to take to a shop for repair. There is high voltage inside your tv that can hurt you, if you are going to try and do this yourself then be sure and unplug the tv from ( AC ) still there is a good chance that there is still high voltage in the set even after you let it sit unpluged for a day or longer.
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
