Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a yth2348 riding mower and I changed the oil and the oil change display on the hour meter come on and stayed on. How do I fix this problem.
Posted by ogle8799 on
Anonymous
    New Friend:
Husqvarna YTH20K46 How to get change oil display to go off
Posted on Sep 28, 2010
I have an ST2046 snapper riding mower. I changed oil and oil light still will not go off.
Sometimes mowers, like cars, are pre-programmed to display service interval lights after X number of hours. You may have changed the oil just before such an occurence. I'd give it a few more running hours and it should turn off. Check the manual regarding the oil change interval and the warning light.
Jul 02, 2016 | Snapper ST2046 46" 20HP Lawn Tractor 2014...
Low on oil ,added oil monitor won t stop blinking is there a reset button disconnected battery still blinking
The hour meter displays the total operating
time.
It will flash CHG OIL (Change Oil) at 50 hour
intervals. The flash duration is one hour
before and one hour after the interval. The
CHG OIL icon will come on and shut off
automatically. The hour meter can not be
manually reset.
Aug 09, 2011 | Husqvarna Zero Turn Mower Z5426
Light came on for oil change - oil is changed is there a 'switch' to get it back to be able to start?
Hi, the oil change light will go off in two hours running time. It does not stop the mower from starting. If your mower will not start you have an unrelated problem. Hope this helps, regards Phil
Jun 24, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Ch6 Oil code
Hello, W/D here.
What you are actually getting is Chg Oil (change oil). This is preprogrammed in, as a reminder for you to service the engine. It will go back to the hour meter mode after about 1 hour of additional runtime. If you have changed your oil and filter, there is nothing else to do. The oil and filter need to be changed regularly. If the oil breaks down in your engine, it will lose it's lubricating properties and the engine will seize up.
Best regards, --W/D--
Aug 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Trouble code ch6 oil on hour meter
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
May 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
815 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
