Thats a convergence issue. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs , resistors and the CD with instructions.
SOURCE: 53" Panasonic HDTV showing letters and shadow
See http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html I did this successfully on a PT-53TW53G, as per my separate post on fixya.
SOURCE: i have a phillips rear
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
SOURCE: green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
SOURCE: Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
