Set on-off times by setting trippers
-Insert trippers
-Red tripper is ON
-Black tripper is OFF
-New timer has 2 sets of trippers
Set time
-Plug-in & turn-on power pack
Turn dial clockwise to set time of day
Manual override:
Turn manual-on-off switch counterclockwise
Troubleshoot:
-Power pack not turned on
-Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
-Manual-on-off is set to OFF > rotate to ON
-Outdoor lamp burned out > test with another lamp
-Important to replace burned out lamps promptly, or other lamps burn out quickly
-High household voltage will reduce life of timer
-Timer designed to last for many years under normal conditions
SOURCE: I have a ML200RT-the timer is stuck.
The solution is in the final gear before the timer - it is nylon on the metal casing - and has corroded - happens after winter if left unplugged or stationary. It takes about 5 minutes to fix.
Carefully take apart the gear mechanism - remembering where the gears go. When you take out the final gear - it is through a swaged area of metal - carefully rub the inside of this with emery cloth to remove corrosion etc. Apply a heavy dab of grease or Vaseline.
Re-assemble and you're good to go.
