Question about Thermador SGS36GS Gas Cooktop
I need to replace my Ignitor head on a sgsx365zs Thermador cooktop...I have the part...Do I have to pull the cooktop or can it be accessed from on top?
  • 6 more comments
  • Anonymous Sep 22, 2010
    I don't know hat the Maintop is...Are you talking about whole stainless cook top? or just taking off the burner and leaving the top in place?
    Thanks
    I'm replacing a broken ignition head in my thermador cooktop sgsx365
    It seems I must remove the burners with a 20MM socket to get the SS top off....Is this true....?
    The brass fitting is really locked on and will not release...Can't get the galv pan to come off under the unit.THANKS, Paul
    that helps, do you have a diagram for sgsx365?
    That's my model
  • Anonymous Sep 23, 2010
    My Thermador sgsx365zs needs the ignition head replaced....It looks like I have to Take off the burners with a socket wrench to get the Ignitor off....Any Ideas? I cant access it from underneath...It looks like I have to work from the top down..Paul
    My SGSX365ZS Does not lift up.....I need a step by step instructions on how to get to the burner ignitor...It seems to be clipped in from underneath...the SS top
    I want to replace my ignition head on my center burner on my Thermador SGSX365ZS...How do I remove it...The SS top does not lift up...Paul
    Top won't pull off........almost ruined the gas lines trying
    Top Won't pull off ...........Tried, It looks like the burners must be removed...My unit is SGSX365ZS,
    Not the one in the picture by my post..Thanks,
    Paul
Nate Stansfield
  • 11,896 Answers
Pull the top off and you can access from there.
Posted on Sep 23, 2010
  • Nate Stansfield
    Nate Stansfield Sep 23, 2010
    You can get all the diagrams free here:
    http://www.appliancepartspros.com/partse...
  • Jill Raynor Leahy
    Jill Raynor Leahy Mar 31, 2014
    It is not so simple to pull the top. Does someone have a DIY video of how to pull the Thermador Top SGS365ZS?
Cool Blue Services
  • 560 Answers
Usually the igniter control module is located in the rear of the unit , often on the right side. Open the cook top from the front , it should be hinged to lift up from the front . Follow the wires to the igniter lead wire and then follow that wire force the rear of the unit or the right side of the unit . If there is no access panel where the wire disappears through a grommet and hole, then you'll have to pull unit to access the rear or side compartment . There should be an access panel which will allow you to open it and access the main igniter module . I have often found that by following the igniter leads I can locate the area where the igniter module is . As you have the new part , and if it came with new lead wires, then by looking at it you should be able to guesstimate where the module is located .
Tom Carson
  • 3,083 Answers
I've never replaced this, but I can refer you to some diagrams and parts lists of your cooktop which might show you where it is and how to get at it:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232227&diagram_id=193384#d193384
Figure 1 shows a detail of the Ignition Plug, but I can't figure out where in the diagrams it is- hopefully this will help you,
Posted on Sep 22, 2010
espressonist
  • Thermador Master
  • 1,711 Answers
In order to reach the ignitor you must remove the maintop assembly which is one unit and it can be pull up. The rest is very easy under the maintop there are the burners and ignitor so you can replace.
Here is a link so you use as a reference.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110053&diagram_id=192367#d192367
  • espressonist
    espressonist Sep 22, 2010
    Yes the maintop is the complete st. steel pan this can be pull up after you will remove the secure screws
Frozen locknut on burner Thermador SGSX365ZS
First I would try heating it up until it is red and then twist it off. If that is not an option for you then I would get a rotary tool (hobby size) with a cutoff wheel and carefully cut into it from the side about halfway through. That will get it.
Apr 09, 2014 | Thermador SGS36GS Gas Cooktop
The ignitor wont stop clicking on all burners
The wires to the igniters need to be replaced, our did the same and drove the technician nuts for 6 months...he wrapped them in electrical tape after seeing one arc...new wires fixed the problem.
Sep 16, 2013 | Thermador 37 in. SGSX365 Gas Cooktop
Hello I have a kenmore elite gas cooktop with only one burner lighting normally. The rest we have to use a match. Can I change a part to fix this?
Yes the ignitor can be changed out. If you give me the model # of your unit I can get you the part number you need to replace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 17, 2010 | Thermador SGS36GS Gas Cooktop
Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
Mar 11, 2010 | Thermador 31 in. SGS304Z Gas Cooktop
The cooktop igniter wont stop firing even when turned off
one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad.
Jan 13, 2010 | Cooktops
One gas cooktop does not light, no gas smell
Hello Liz. The most common reason for the problem you are experiencing is greasey dirt in the burner. Use a small brush, some fine wire and some degreaser to clean up the burner. Then let it dry overnight and try it again. If it still won't start, you will have to replace the ignitor.
Nov 28, 2009 | Thermador SGS36GS Gas Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Aug 27, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador SGS304 Ignitor does not spark
Hey Frust1
check that the particular burner is properly "grounded" see that no "dirt" is between burner and frame. Also ensure that the insulation on the wire from the igniter unit to the probe at the burner is not damaged.
Regards
Aug 14, 2008 | Thermador SGS36GS Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
Top Thermador Cooktops Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Dale Copeland
Dale Copeland
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
