NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
Air
Temperature Control Blend Door Failure No Heat
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
