Razor USA Razor Dirt Quad Electric ATV Logo
Posted on Sep 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Electric Razor ATV that I am having issues with. It is showing fully charged but will not go. I have checked the fuses, put a new throttle and computer module in it. I am showing 20 amps to the rear motor. I have lifted the back and tires turn about 1 inch and then stop. There is no grinding or noise at all. Any info or other trouble shooting ideas would be great. Thanks
Anonymous
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Apr 04, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
76200
Points
122
This is not a gasoline operated right? So the problem may lies beneath the control panel or motor it self.
ITP tires
1 Related Answer
Anonymous
  • 636 Answers
  • Posted on Jul 24, 2009
SOURCE: I have similar problems with my razor mx350.
sounds like the CDI box is shot. This should be located either under the seat or the left rear side of the fuel tank if memory serve me correct.Fairly cheap part 20- 25 bucks.
I have an electric Razor Dirt Quad. It ran perfectly until it rained, now nothing. I replaced the control module and batteries. It turns on but 'low power' light flashes and it does not run what next?
Question edited for clarity.
Question moved from Cars and Trucks.
Get out your multimeter and check the TOTAL voltage. You should have 24 volts or 36 volts depending on model. If you don't, take them all of and charge each one on a car charger set at 2 amps. Clean all the battery connectors with a wire brush and also the connectors. Smear them with Vaseline. Also make sure you have the batteries wired in correctly. If don incorrectly, you may be running on 12 volts!
https://www.google.com/search?q=razor+quad+low+power
Batteries x 2 or x 3
https://www.google.com/search?q=razor+quad+batteries
Two trail boss Polaris atvs. they have sat for about 4 years. I put in new batterys no power going to any thing. Is there any type of fuse or any thing that could have go bad by sitting too long.
no year[s] given yes their are fuses and battery fuse newer have a breaker -----do online search using year make and model for service manual[s] most polaris atv manuals are available free pdf online this one is an example ------------------ https://www.manualslib.com/products/Polaris-Trail-Boss-325-5904729.html
Apr 20, 2019 • ATVs
1helpful
When you turn throttle on top sprocket turns freely but when chain is on it will not turn th wheel
It has an electric motor I would check the sprocket on the motor see if it has a key way it could of broke or fell out
2answers
What stops my engine starting
power wire and ground make starter work inside starter case. the power wire goes through several safety switches on way to starter. check each connector 4 loose wiring. battery (-)to engine and frame need more history here b4 i can help anyymore. good luck
I have an electric razor quad,how do I know if the batteries are good or bad,I just purchased a new charger to try that.If that does not work any suggestions.
the charger probably has a meter on it, you can check voltages with it. remember that the battery connectors must be tight, but don't break them.
Seems to have a bad connection...
take a OBD2 scanner to have check, maybe you will know what is problem.
car diagnostic tools
Quad is charged but on switch does not turn it on
Check the ignition switch it self. Or the starter relay, it may need replacement.
ITP tires
Top Razor USA ATVs Experts
john h
Dmitry Isayev
Dmitry Isayev
Are you a Razor USA ATV Expert? Answer questions, earn points and help others
