Assuming that you have created a shard folder before, "Sharing Files and Folders" should be enabled on your machine.
Go to your Control Panel -> Folder Options adn click the "View" tab. Scroll all the way down and
disable "Use simple file sharing (Recommended)".
Now the "Sharing and Security" option should appear again if you right-click a folder.
Microsoft has a write-up on this for general information. See
here.
In regards to the possible Trojan - I would need the exact file name to find more information. What you can do from your end is to run an online scan with
Kaspersky WebScanner.
Note: You should use Internet Explorer to run this scan, and you must disable your Anti Virus program during the scan.
Click the Accept button.
You will be prompted to install an ActiveX component from Kaspersky, Click Yes.
* The program will launch and then begin downloading the latest definition files:
* Once the files have been downloaded click on NEXT
* Now click on Scan Settings
* In the scan settings make that the following are selected:
o Scan using the following Anti-Virus database:
Extended (if available otherwise Standard)
o Scan Options:
Scan Archives
Scan Mail Bases
* Click OK
* Now under select a target to scan:
Select My Computer
* This will program will start and scan your system.
* The scan will take a while so be patient and let it run.
* Once the scan is complete it will display the results if your system has been infected.
o Now click on the View scan report link:
* Click the Save report as button
* Under Save as type, choose Text file (*.txt)
* Save the file to your desktop as Kaspersky.txt
* Copy and paste that information in your next post if you like.
If you have any more questions, or file sharing is still not working, just come back here and leave a comment - I'm happy to help.
