Question about OKI C Office Equipment & Supplies
OkiData printers connected to 170x print server stop - and have to be set off-line then back on-line to continue printing the 1-page invoice jobs being sent to them. They are running on a SCO 5.0.7 system with printers that used to be connected as serial devices, and didn't have a problem
Posted by dnorth743 on
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
ginko
Ginko
  • 19396 Answers
SOURCE: I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
Posted on May 09, 2008
Anonymous
  • 53 Answers
SOURCE: Jetdirect 170x External Print Server Not Visible over network
it is possiable that a firewall is in the way, but more likely is that you are on a different logical network or subnet.
the HP software relies upon doing a broadcast to find HP printers, broadcast traffice is not normally permitted between subnets, this is why the HP software does not find your printer.
basically you need to creat a new port on the computer in question and then associate a printer to that port.
do so by doing the following on XP pro.
get to the printers folder then click from the menu "File"
click "server properties"
click add port and then double click on the (Standard TCP/IP Port) a new wizard opens click next
in the top box enter the ip address of your printer. and click next. leave the device type as "Standard and as generic network card) click next then finish. then close.
now you have to link your printer to your new port.
install a new printer
making sure that you select local printer... but removing the tick "Automatically detect......" then click next and select LPT port 1.
click next choose HP on the left colum and HP lasterJet III from the right colum. click next give the printer a name of your choosing. and if nesseary choose if you want it to be a default printer or not.
click next and leave do not share selected.
click next
on the "do you want to print a test page " select "No"
then finish.
once done
right click you new printer select properties
then select the "Ports" tab
scroll down the list until you see new Standard TCP/IP port listed, select your port. then click apply
lastly click the advanced tab
using the driver part of this screen you are able to select the correct driver from the dropdown list if it is not avaliable click the new driver button and follow the prompts.
click OK when done.
hope this helps.
selecting the HP Laser Jet III making sure that the
Posted on Nov 08, 2008
Anonymous
  • 76 Answers
SOURCE: Half a page prints only. Continues a single page on a 2nd page.
check the print preview to see if that is how it's formatted..otherwise, you may need to install new drivers
Posted on Nov 21, 2008
Anonymous
  • 65 Answers
SOURCE: 4100 stops printing mid streem and engins continue to run
Try printing out an error log and seeing if that leads you anywhere.
Posted on Nov 25, 2008
Printing trouble, OKI microline 320 Turbo. All of a sudden it's not printing the right side of the invoice. I have no idea how to increase the printing area so this doesn't happen. Please help!
There are 3 competing controls. 1) Software 2) Printer driver 3) Front panel. Software control overrides printer driver. Printer driver overrides front panel. Your software settings therefore dominate. That said, you can choose to have the front panel settings "dominate." Those front panel settings may enable you to change margin widths. Even though this may be possible, you may well find the solution is within the invoice software's print setup where you may have to check some box to enable 11 inch printing or whatever is required. But that requires knowledge of the invoice software program. I am unable to determine if you are encountering a sudden failure of a system previously working. If this is a printer failure rather than a software configuration problem, you will have to check the okidata help.
Here is some reference material:
Okidata Users Manual ML320 ML321 Turbo Problem 1 My word processor files...
Apr 11, 2018 | OKI Office Equipment & Supplies
How do I set up an HP JetDirect 170X Print Server with Windows 8.1 Operating System?
Connect the printer to the print server. Push the test button on the test button on the print server. Two pages will print. One of the pages will contain the IP address for the print server. Connect the print server to the router. Now you need to go to the Control Panel and select "Devices and Printers". Select "Add a Printer". When it searches for a printer, select "The printer I want isn't listed". Next, select "Add a printer using TCP/IP address or hostname" and click "Next". Now, enter the IP address from the test print and click next. That will do it.
May 28, 2014 | HP Jetdirect 170x Print Server
How to specify a host name for jetdirect 170x
Connect the print server to the router with an ethernet cable and connect the server to the printer. Find the IP address for the printer/server by pushing the "test" button on the print server. The IP address will be listed on the paper printed during the test.
Nov 12, 2013 | HP Jetdirect 170x Print Server
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
Aug 11, 2009 | HP Jetdirect 170x Print Server
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
Jun 05, 2009 | HP Jetdirect 170x Print Server
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
103 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
