1998 Ford Windstar Logo
Posted on Sep 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The needles on my gages stopped working, a beeping sound occurred (5 beeps then stopped), the car radio went dead, then the car hesitated and died.
Colin Stickland
Level 3:
  • Ford Master 22,516 Answers
  • Posted on Sep 22, 2010
Colin Stickland
Ford Master
Level 3:
Answers
22516
Questions
Helped
6998432
Points
66324
Battery flat ,alternator not charging
I was driving my lr2 and heard load beep then all instraments went dead on dash, radio and rir still work but when i stopped and put in park throtle stopped working and can not shift out of park.
It sounds like you have a dead battery or a total loss of power in the electrical system, this would be an issue that will require some special testing.
A warning signal non stop
If it is constant cycling beeps it is because it is in factory mode, when the car is new and you input the code it usually cycles beeps through all the speakers one after the other, it takes up to 5 minutes to stop and then will work ok, if it is a beep when you put the code in then the code is wrong, there is a 4 digit pre code on the side of the radio, if you go on renaults web site and put in your chassis number then the pre code, it will give u the code that renault gave that stereo, costs 15 or a dealer can also do it for you.
2answers
When headlights turned on the dashboard lights dim and after 5 minutes a warning sound comes on.
Sounds like your charging system needs some attention.
1st check battery for voltage should be 12.50 or better with car off
2nd, start car check battery for voltage again should be 14.0 to 14.75 volts.
3 with running turn on headlamps and check charging voltage again if your voltage dropped to battery voltage your charging system is not working.
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
1helpful
Dashboard went dead
alternator.
the vehicle was running off the battery.
if the battery was bad,the truck would run fine off the alternator.
get an avr test done/
1helpful
I hear 5 warning beeps then a pause then 5 beeps again
Get the battery situated, and your beeps should go away. Sounds like an errant security horn from a sloppy connection. Interested to see what happens. TT
5helpful
3answers
Beeping
When you turn key on check if airbag light on instrument cluster comes on. 5 beeps is the tone to let you know your airbag light in instrument cluster is inop..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/terry_db4da071b7da3ac1
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
