SOURCE: Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
SOURCE: tasco nv 356 night binoculars
Check the HV to the tube and see if you can see any discolouration or spots on the tube - they often indicate tube failure. Many binoculars use the one power supply for both tubes as the current demand is very low. Often, one tube operation indicates tube failure, but a wire or connection could be at fault.
SOURCE: does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
SOURCE: need battery
Check with; www.rugift.com they sell these russian NV and will probably have the batts or have a source. Good luck. :)
SOURCE: battery replacement for Night Owl Night vision monocular
just press down and away from the lens, on the ribbed square located on the spine of the monocle
