Question about Simplex Kaba E-Plex 3000 Narrow Stile electronic keyless lock
Zero old key code and enter new key code on KABA electronic keypad
Posted by tbtaylor54 on
Coaltowner
  • 963 Answers
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Mar 06, 2011
Reprogram master code
on the keypad press the following...
(old master code) wait for green light
press and hold AL key until multiple beeps are heard. this puts you into program mode.
TO ENTER NEW MASTER CODE press the following keys:
  • AL 1 AL (new code) AL (confirm new code) then press the star key
  • to EXIT program mode hold down any key for 3 seconds
  • test new master code
Jun 23, 2014 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Kaba lock won't open with code
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
Have simplex lp1000 keyless lock sytem is zeroed out but will not reset or take new code, aleays stayes unlocked
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Oct 31, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Model 1011... door opens without any combination. how do i fix the lock to open only with combination?
Aug 15, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Door opens without any combination. how do i fix the lock to open only with combination?
Opens with out a code and can not get it to stop pulling the latch back. i tryed to put a new code in but cant grt past step 2
I THINK that the problem you describe is because the lock is in "Zero Code":
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE."
Go to this web page:
and position your mouse on PDF under the "TIPS" (rightmost) column on the grid line for the L1000.
Two choices will pop up; click on the upper one "Changing the code/Combination...." and download and open this file.
If it does not open, you need to download and install Adobe Acrobat on your computer from here: http://get.adobe.com/reader/ It's free!
When you get this document open, you will see the statement that I quoted from the top about the Zero Code. At the bottom of the document you will see:
Troubleshooting
Symptom/problem: Outside knob/lever when turned always retracts latch without depressing
any buttons.
Cause: Lock is in zero combination.
One last nasty piece of information: If you don't have the necessary DF-59 Key or spanner wrench mentioned in the procedure, you can get either from these sources:
Key:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Whew! That was a lot of stuff, to digest, so I hope it helps. Good Luck!
Jul 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Cannot get it to accept the user pin numbers. Have entered the master code and also reset the manual reset to default.following the manual and using the # sign before and after master code. red light comes...
Recommend that you contact Kaba Ilco with your problem.
Jul 01, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
Had to replace a return spring under the clutch and now the clutch arms won't reset the combo pack if a wrong code is entered.It does work if the right code is entered
I recommend that you contact Kaba Ilco directly with your problem.
Jan 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When i turn the knob without entering the combo, the door opens. When I enter code, the door doesnt open. The passage knob is in the correct position.
Jan 07, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba E-Plex 3000 Narrow Stile electronic keyless lock Logo
369 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
