Question about Eureka 1934 Bagged Upright Vacuum
I have a Eureka The Boss Power sweeper but can't find my Owners Manual. It seems to have lost some vacuum power. It doesn't pick up cleanly, leaves a streek of residue behind and seems to be blowing air out of the right side. How can I correct that? Thank you for you anticipated reply and assistance. D.J.POtts
Posted by dompottsesq on
Robert V
    New Friend:
  • 110 Answers
Blowing air out of the right side? As in blowing air out of the right side of the hood? If its a light stream of warm coming out of the vent in the hood that's normal, its exhaust air from the motor. Now, clogs can occur at the outlet from the fan chamber. Remove the bag from the base of the machine via two screws. See if that area is clear and the tube going up into the bag unit is clear as well. Now, if the fan chamber is clear, inspect the fan for breaks or missing blades.
Posted on Dec 21, 2017
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: Eureka Central Vac-Sweeper -Model B1501
Its not easy to get into the sweeper head. I would push a air hose in there and blow the head clean. You will need to find a compressor or your friendly local workshop manager could help you.
Posted on Nov 08, 2007
Anonymous
SOURCE: Eureka Boss vacuum just quit
You have a clog in the hose (or somewhere) most likely the hose though. Find the clog -clean it out-let the machine cool down and you are back in business. This is really a good feature of the Eurekas because rather than continue to run and burn up the motor it shuts off -you clean it out and your vacuum is saved.
Posted on Feb 16, 2009
Anonymous
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
Anonymous
  • 46 Answers
SOURCE: Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Posted on Jul 25, 2009
Howard Galley
  • 197 Answers
SOURCE: My Eureka Boss Widetrack leaves debris behind
check for blockages in the brush bar compartment and hoses
Posted on Sep 28, 2009
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
Jan 21, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Download parts and operators manual
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 | Vacuums
Eureka 1934 Bagged Upright Vacuum Logo
115 people viewed this question
Top Eureka Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Mike
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
