Aiwa CDC-X227 CD Player Logo
Question about Aiwa CDC-X227 CD Player
I have 2 of the same radios and one cd player works but my rca plugs are broken and the other one reads EO3 can i switch the cd players in them
Posted by scoobydoo_on on
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Aiwa Master
  • 2,226 Answers
If they are the same radio, you can definitely swap cd mechs.
Posted on Sep 22, 2010
1helpful
Rca rs2767i
your cd player is broken check go and get a replacement
RCA Alarm clock with cd player, CD will not read discs
cd players have their laser fail often. How old is it? A three year run with a player is not bad.
2helpful
Cannot get my mp3 player to operate on the aux input consistently
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
4helpful
2answers
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
4answers
Cd player
I would first check for a broken or disconnected wire or cable. then check all of the fuses. After this the unit will need to come out of the car and be bench checked. Good Luck
Top Aiwa Car Audio & Video Experts
AAA TV Service
AAA TV Service
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
