Question about Hotpoint RFA60 Bottom Freezer Refrigerator
My Hotpoint RFA60 is displaying it's High Freezer Temp light. The freezer has become less efficient. How can I fix this
Posted by stuart_gay on
geoff hunter
  • 4,793 Answers
If the unit has iced up then the efficiency will drop considerably.do a 24hour total defrost and dry thoroughly.DO NOT use hairdryers/scrappers as they only deice the surface ice.....if that dont work get back, as its free.....
Posted on Sep 22, 2010
Samsung RF25HMEDBSR bottom freezer fridge. Fridge is at right temp.,ice maker works, but the bottom freezer is not working.
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator/freezer becomes less efficient, causing it to work harder to cool down. If the coils are significantly dirty, it will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty. All models have coils in an enclosed area usually accessible via a vented cover at the back of the refrigerator. These coils help to keep the refrigerator and freezer cool. If these coils become too dirty from dust or other particles, the freezer may not work as efficiently.
unplug when taking the vent panel off to clean. bottle brush or a vacuum attachment be careful not to bend aluminium fins.
Jan 30, 2018 | Samsung Refrigerators
I need a new door for the freezer section of my RFA60. Where can I get one?
Instead of replacing the door--- just cover it instead.
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.
They have solid colors, designs, textures and even stainless steel options.
Worth checking out.
Nov 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
In the last few days the red light has come on on my hotpoint RFA60 Fridge Freezer. The food in the freezer has remained frozen until today when it has started to defrost. There also seems to be a slight...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
How do I unblock the moisture outlet?
canned air, wire hanger, anything thick and flexible.
Nov 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer has defrosted itself fridge still seems to b workin but warnin light for freezer temp is on? Iv tried the fast freeze but it hasnt worked
is this a manual type unit or just a chest type freezer if just a freezer as soon as it reaches a temp of 08 the alarm should stop
Aug 19, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
308 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
