It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
1. Unplug all of the cables and cords from your GV42L
FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and
flat surface (blanket, foam, cloth, etc) to prevent any
damage to the TV.
3. Pull the stand cover off by squeezing the sides to
release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws
(screw's specs: M4, 0.7 Pitch,
15mm long) so that the stand
base can be removed.
5. Gently remove the stand
base
6. Now, the GV42L FHDTV10A can fit securely to a
mount (sold separately) by utilizing the mounting
holes in the center of the back panel of the TV.
Please make sure to read the instructions of your
specific mount to properly hang the GV42L
FHDTV10A
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4 If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
The price range is 500-800 depending where you will get it, try Ebay and look for a non-working one with a good panel (screen), it does not matter why is not working as long as the panel is in good condition.
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
