Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
I have a samsung RS2530 Series. Where do I adjust the temp.
Posted by sierrah_2 on
Anonymous
    New Friend:
How do you adjust the temperature
Posted on Oct 09, 2010
marquez
    New Friend:
My refrigerator is a samsung rs 2530 bbp. The lights shut down and the refrigerator is over cooling, up to the point of freezing vegetables. What can i do to moderate the temperature?
Posted on Sep 21, 2018
Samsung RS2530 B...flasing green light on freezer side will not turn on...
sorry but i hate the lg and samsung products. they have some unusual error codes. a flashing light doesnt describe enough of what is happening. try doing a google search for samsung error codes and then get back on here with the actual error code and maybe i can help from there.
Dec 31, 2013 | Refrigerators
Samsung rs2530 screen went blank except 1 lights bar flashing on freezer and wont cool
The one light flashing on the display is an error code. Depending on which light is flashing will tell you what the error code is. Check the link below to see if it has the error code. That should give you an idea of where to start.
Samsung Error Code List
Mar 16, 2012 | Samsung Refrigerators
Samsung RS2530 Series Model RS2530BBP Twin Flow 25 cubic ft. I just bought a house. This is the refrigerator. It is making annoying motor noise at night. I need a manual for this frig.
Click Here=> RS2530BBP User Manual and if you need Product Support Click Here=> Samsung Appliance Support and if you need Technical Support or out of warranty feel free to ask me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 22, 2010 | Samsung Refrigerators
Samsung RS 2530 REFRIGERATOR is always too cold and even my drink insied will become all ive tube!! and the part of making ice tube is broken, too. it can not creat the ice and ice water
The model RS2530 was a Best Buy model and possibly has only one evaporator in the freezer compartment. Sounds like you are having a couple problems. The dual water control valve is leaking for the ice maker and causing the water to freeze in the fill tube for the ice maker. A mess I know! As for the too cold problem I believe that is related to a thermistor located insid the fresh food compartment that is defective or a auto damper sticking open and allowing cold air to flow without control into the fresh food section. i'm sending you a service manual that covers the next model up than the model you say you have. I would like you to tell me as you look through the manual any diffences you notice and there will be because Best Buy made the RS2530 a basic model. It is possible the problem will be the auto damper if your is this mosel. Click here=> RS2531 I will need you to work with me on this one to resolve these problems. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Here=> Sea Breeze Tip's
Feb 24, 2010 | Samsung RS2534 Side by Side Refrigerator
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
My side by side samsung RS2530 bbpfreezer is not freezing any ice
Are you taking too much ice in too short time? The freezer needs some time to freeze the water to form cubes. Another reason is that the water supply line may be blocked by air bubbles. Ensure that the water supply is adequate.
Aug 07, 2009 | Samsung RS265LABP Side by Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
539 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
