Question about Watches
I own tag heuer waf 1010. Hands do not line up properly on the hours or minutes. Example, 10:20pm, the hour hand is just below the 11 hand. Watch is 2 months old. Help
Posted by richyrich767 on
David Tolond
    President:
  • 2,501 Answers
You should have been given a set of user instructions with your watch but obviously they are missing.
TAG are not helpful on their web site as they do not give dwownloads of instructions for some of their watches, so I suggest that you either contact your supplier and ask why there were no instructions with the watch or contact TAG http://www.tagheuer.com/login/?urlBack=/mytagheuer/index.lbl%3Flang%3Den to find the nearest stockist who will be able to sort it out.
Posted on Sep 22, 2010
I dropped my aquaracer watch on the ground from 2 feet high. hour and minute hands not moving but the second hands working fine. please help!
You need to go to a watchmaker. Sorry, I am good but not good enough to diagnose the damage without seeing the watch. In any case you can't fix yourself unless you are a watchmaker.
May 24, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
MY TAG FORMULA 1 WATCH KEEPS STOPPING AT 11.20 BUT THE SECOND HAND KEEPS GOING.
mcdevito75 here, It sounds like the (larger) minute hand is leaning against the (smaller) hour hand, stopping the time telling past 11:20 while the seconds hand keeps going. You"ll have to see a Watch repair person and have them look at your watch. Best Bet, look for a small watch repair shop in your area.
Aug 25, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
The hour and minute hand are sliding around the face of watch every time I move my arm. The second hand is still moving correctly. Thanks.
It appears that the hands are loose an need to be by an experienced watchmaker.
If you have any further questions please let me know.
Many thanks! Mike Kenley ([email protected])
TimeOut Worldwide watch and clock services If it don't tick I can fix
Nov 30, 2009 | Tag Heuer Link Quartz WT1313.BA0557 Wrist...
Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Aug 24, 2007 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
121 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
