Can not find wiring diagram of rear entertainment sytem nor fuse or relay location. It's not in my Chilton repair manual nor does owners manual metion it.
Go to the link http://www.chilton.cengage.com/ to download the latest manual for the model
2001 Ford Expedition Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Violet
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Violet/White
Right Rear Speaker Negative Wire (-): Light Blue
The fuses should be in with the main fuse box and the wires should run from the stereo to the speakers. Please let me know if you have any questions with this. What exactly is wrong with your entertainment system?
Can I suggest buying a Haynes Manual which is similar to a chilton manual from a local fleet farm, NAPA, AutoZone, or Checker Auto store. These manuals will have complete diagrams of everything for your vehicle and for people that like to do everything themselves, they are a great resource to have and will save you from dollars of mechanic work.
Please update me about this and I would be glad to answer any other questions that you may have. There should also be a fuse relay under the hood.
Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
thanks and Have a Great Day!
Where is the fuse located exactly because I called my local ford dealership and he said the only fuses were in the fuse box for the entertainment system. Of course it wasn't my friend who would have known since I'm not as familiar with this model but I figured any other guy there would've known just as well. Sorry about not being more help
thanks for letting me know, I'm sure it will be helpful in the future, have a good day
I fixed the problem myself. Without any help from anyone.Chilton and Haynes have the same diagram for the Rear Entertainment System.As I stated I am a ASE certified Master Tech.The reason That I spent the money for help was to save time. For everyones information there is a separate fuse for the system..
Hi bestdarngood,
Tennima speaking here.I will go ahead and tell you where the RSES fuse is located. I founnd it by taking the top of the console off. Only two screws-One located in the front of console lid and the other under the removable rubber square storage tray at the front of console top cover.There you can see the wiring harness going to the Video cassette player.The power wire feeds the stereo system as well.It is black with a pink stripe. You will see two black and pink wires running by themselves to a single small white fuse holder in the very font of the console. It is a wide spade seven and a half amp fuse.Total replacement time with the correct information is about twenty minutes. You may get a kick out of calling the Ford dealer guy back and tell him where the fuse is.I worked for Ford,Lincoln Mercury dealer for over four years.They are just like the rest of us at times mistaken and too quick to answer. I hope this information will help someone.
