SOURCE: MY ZENITH MODEL # Z60Z83R8 BOW'S VERTICALITY
You have a problem MOST LIKLY!!, that happens to almost if, not to all projection tube sets ever made. Its the old bad convergence IC falure. It's not something you can do unless you have had exstensive electronic training and soldering skills. There are no user replaceable parts inside of this set so please call out a pro to repalce the convergence IC for yop! A repair such as this should cost around 250 to 400 bucks, depending where you live..Good Luck
SOURCE: zenith tv no pic
You have a picture when you're watching a DVD, but none when you're watching regular cable? Does the audio appear to be okay?? Are you sure you've switched the inputs on the TV back to main???
Let me know..
Bill
SOURCE: Is there no way to fix it?
convergance ic are bad
if you dont want to repair yourself you can go here
www.ptscorp.com
if you do it yourself go here:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
SOURCE: Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
SOURCE: Color Fading on Zenith E44W46LCD
I have this TV. Lamp indicator came on and freaked us out so we shut the TV off until we could find a reasonably priced bulb. I bought a lamp (bulb) from discount-merchant (best price!) and we changed it out...easy enough process, however the "change lamp indicator" orange light remains on and the TV now has a lovely yellow spot in the middle of it. After arguing with my husband that he didn't install the lamp correctly, I have read for the past two days MANY of the same issue with this specific TV. We've had it 5 years in August so I guess that is about the life of this TV and a big apology to the hubby. :)
