Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the
QuickVerse version 7 Essentials CD into optical drive & close tray.
This begins the auto run / install process. (Please do not remove CD
until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message
box appears at the end of the installation: “QuickVerse installation
has encountered a problem and needs to close” Choose “Don’t Send” The
installation program exits.
Navigate to: Start Button / All
Programs / Parsons / QuickVerse 7 / (from drop down list) find
“QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog
Box appears, “The librarian datafile library.mdb not found etc…” Select
“New” / "Open Book" dialog box appears click on “Close”
Now with
QuickVerse 7.0 running go to File / Add Books. “Registration Guide –
Introduction” box appears. Choose “Next” The path to the new collection
to register should identify the optical drive (with the QuickVerse CD
already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP
Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight
QV Essentials in the LH pane. The RH pane shows all the books present
on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and
drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
