Question about Lexmark X7170 All-In-One InkJet Printer
I need to learn how to use my printer as a fax machine.
Posted by rbailey8391 on
I have my machine hooked up with my answering machine. How do I set up to have the answering machine pick up and then once the beeping of a fax starts, it will connect.
Unfortunately you can't do that with any stand-alone answering machines. You'd need to manually activate the Fax when you hear the fax tones. What you can do is use an item like this: http://faxswitch.com/stick.html or this: http://www.usr.com/en/products/telephony-usr4000/ to route the calls to the Fax or the answering machine for you. The other option is to use a TAPI Voice/Fax Modem with your computer that supports telephony operations. Then you can use the computer to answer the fax calls and telephony software to add an answering machine to the computer. (This is one example: http://www.ventafax.com/ .)
I wish that I had better news for you.
(Note: I have a USB Voice/Fax Modem that claimed it would handle telephony operation after a firmware upgrade to the unit. It never learned how to correctly interpret the necessary codes. This may be a driver issue but I never resolved the problem. So my fax modem is still on Manual answer.)
May 12, 2015 | Canon PIXMA MX922 Wireless All-in-One...
MY PRINTER NOT COMUNICATE WITH COMPUTOR
send computer and printer to counselor to learn to communicate?
Seriously you need to post details!
Feb 11, 2015 | Brother LC-61 LC61BK LC61C LC61M LC61Y...
How to send a fax
Sending and receiving faxes online is simple using
Fax Internet Service - (just for USA)
Aug 29, 2014 | Brother MFC-215C All-In-One InkJet Printer
How to receive fax in brother printer mfc-465cn
Welcome to Fixya.
Please follow the link specified below as this will direct you to Brother's site where you can view/download the comprehensive user's manual :
MFC-465cn Manual
You will learn how to make the most out of your printer by going through this.
Thanks for using Fixya.
Jul 01, 2011 | Office Equipment & Supplies
My copier/fax machine says it is out of toner. It is NOT. I have tried unplugging it and then plugging it back in, but it still will not print. What can I try next? Thanks so much Shevelia McGuire The...
If a cartridge filled with toner you need to check the status of the flag. The flag is under the side cover the toner cartridge. Partner code flag in the cartridges that came with your printer. In cases when filling bolshtnstve forget to pay attention to the position of the flag, and he is responsible for identifying the printer of a new cartridge.
Jun 28, 2011 | Brother Office Equipment & Supplies
Hi if i am out of yellow toner on a clx 3170 can i make it only print black? how do i set it so it will only do black without bringing warnings up say ing toner is out
Unless you have a miracle printer, you have learned a lesson that most of us with color printers have already learned :-) You don't
My education came with a Xerox fax machine with 11 mL ink cartridges. I was only using it for faxes, but the ink evaporates. It's long gone and I've never bought or recommended a color printer to do a black and white job.
Carl
Apr 21, 2011 | Samsung CLX-3170FN All-In-One Laser...
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I can't send faxes on my Canon Pixma MP530 on digital phone line
They're telling you your hardward doesn't play nice with their hardware. A few suggestions:
Update your printer, and see if any improvement is found:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
If that doesn't work, see if your computer has a fax modem that itself can be updated and can support the hardware. Your multifunction printer has a scanner; you can scan in the things you want to fax, then fax from the computer if the computer can fax. This is starting to look like a Dr. Seuss book.
You can also try to learn more about what the problems are and look elsewhere. Your "digital" phone is actually voice over Internet, something VOIP. If you Google for VOIP FAX you'll find some information, like this:
http://www.3cx.com/PBX/FAX-VOIP.html
Dec 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Super G3 Advanced Manual
my printer makes a grating sound and then half the time it says error can't print. What is wrong? We have to plug and unplug it all the time
Nov 01, 2008 | HP LaserJet 3300 All-In-One Printer
Lexmark X7170 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
