SOURCE: connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
SOURCE: how to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..
SOURCE: what is the default IP
Hi, I am Steve, lets get you some help
the IP address you need is 169.254.128.132
SOURCE: AP is broadcasting SSID but can't get ip address
It sounds like either a faulty cable, a loose cable (i.e. not plugged in securely), or failed autonegotiation, or the port on the switch or WAP has somehow become disabled. Since that model of WAP has auto-crossover capability, using a crossover or regular network cable would be irrelevant. What kind of switch are you plugging it into? Cisco switches, for example, can have MAC restrictions or othe security features. I would replace the cable with a known good one first, and examine the log on the WAP as well as the switch (if it's a manageable switch). Let me know how you make out and we can do some further testing if you'd like.
SOURCE: cant connect to xbox live with dlink 635
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
