I just had my lamp replaced for my TV and the technician did an EXCELLENT job of setting the Brightness, Contrast, Color, etc to the point where my TV looked like an LCD TV. However I just moved and the settings were lost. Anyone have the best settings for a great picture? Would come in handy since we're having Verizon FiOS installed and with a straight-to-the-home fiber optic connection, I wanna make sure the TV really shows that!
Thanks!
Factory setting. Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Dark Picture to no picture
Probably has some bad solder connections in the deflection/ power supply area, if you dont know about electronics, might call a repairman and put a few hundred $ into it or junk it, also it is not HD, just FYI
SOURCE: Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
SOURCE: Mitsubishi WD-62527 replacement lamp install and brightness low
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
. Sharpness Adjusts the crispness of edges in the picture.
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
