Computers & Internet Logo
Posted on Sep 21, 2010
The hard drive will not show up onthe desktop or in Finer (Obviously, a Mac). The Utility Disk says it cannot be repaired. How can I extract the data?
Time machine on MAC 10.5.8 will not open; error message -43
error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 • Computers & Internet
Hard Disk not reading the content
It seem the folder is corrupted. I assumed you are using Mac, so you may try to repair disk using "Disk Utility". Since I don't know what version of Mac that you use, I don't know what to tell. You may try this link:
Use Disk Utility to Repair Hard Drives and Disk Permissions for your reference. Or, just google how to use Disk Utility. Good luck.
My Emac will not start up. It makes a high pitch noise a few times and then nothing happens. The screen will not turn on at all, it just remains black.
Put your system disk and power up holding down the c key on your keyboard. Once booted up go to the file menu and go to disk utility once open see if your hard drive is showing up. If it does run verify disk to to check whether your hard drive needs repaired if it does run the repair disk on it. That should get it up and running. However if your hard drive does not show up it is possible that the hard drive has failed. You would then need to replace the hard drive. Hope this helps.
2answers
When i turn it on it's saying there's no such file directory. It's a dual core processor I tried to switch it from Os9 to Os10 and now it's got a black screen with this on it
Try starting from CD and check hard drive. Sounds like you installed something that may have corrupted something on your hard drive.
Hard drive will not appear on Mac desktop
open up disk utility ( applications --> utilities --> disk utility )
does disk utility recognise it ?
Also if you click on the apple icon at the top left and go to about this mac --> more information
Then select the appropriate bus that it is on ie firewire or usb does it show up in system information ?
If so then it is obviously detecting it - if you can see it in disk utility it may need a reformat so maybe make a backup of the data you want on another computer and then wipe it and re do it.
If you can post back with a bit more info.
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Maxtor Portable 320 GB External Hard drive doesn't show on my Mac
If you can get a 3rd party disk utility like DiskWarrior because if the disc information has corrupted the computer cannot see it, the utility will re write this and if the drive is OK it will re appear
Top AMS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an AMS Computer and Internet Expert? Answer questions, earn points and help others
