Question about Zenith DVP615 Portable DVD Player
The dvd won't spin. is there an easy fix? - Zenith DVP615 Portable DVD Player
Posted by mrsbnunez on
Washer won't spin and makes noise on spin cycle
Sounds as if it just a broken belt. Take the back off and find where the belt is located to see if broken. Depending on the washer they can be easy to fix
Jan 05, 2013 | Washing Machines
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
The DVD keep spinning but won't play
see the next steps and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Oct 03, 2012 | Mintek MDP-1070
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
Won't spin and does not wash properly
Sounfds like the belt is broken. An easy fix if you are handy.
May 02, 2012 | GE Washing Machines
Washing machine won't spin, drain, or wash
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2011 | Kenmore Washing Machines
Zenith DVP615 Portable DVD Player Logo
126 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
